Bobs Ten
RV-10
45-08.1>5
Prepare Cabin Top for Window Installation
1248 - 1554
Continue to prepare cabin top for window installation.
Drill temporary holes for window clamps.
Install left door window. Minor sanding was required for window to fit in door.
Mask window for window flange using 3M tape.
Remove window.
Mask inner and outer surface.
Install window and mark for shims.
Remove window.
Epoxy appropriate AN960-6 washers to flange as shims.
Install window and verify fit.
Begin work on right side door window. Same procedure as above.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
