Bobs Ten
Date:  8-28-2016
Number of Hours:  3.30
Brief Description:  Remove Heat Valves, Install Oil Cooler Valve
1448 - 1800
I removed the heat valves primarily to modify them to prevent the hinged door from warping when moved. Unfortunately, the design of the doors is somewhat flimsy and modifications were not completed. The door will be fully closed when necessary and I feel this position is the more critical one.
The secondary reason for removing them was to form a better seal using 3M Fire Barrier 2000+ sealant. As this is not available locally, it was ordered and will be here Tuesday.
Next, I installed the linear actuator that will control the oil cooler valve. The actuator was installed and tested for proper travel from fully open to fully closed.
