Bobs Ten
RV-10
Brake Calipers
1600 - 1818 1918 - 2118
Found interference between caliper and whell pant bracket.
Had to remove wheel, brake, brake plate, and wheel pant bracket.
Modified bracket to clearbrake line fittings by removing a small section of the bracket and fabricating a doubler plate.
Match drill doubler plate to bracket.
Cleco then rivet doubler to bracket.
Verify fit.
Re install bracket, brake plate, brakes, and wheel.
Repeat for other side.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
