Bobs Ten
RV-10
Forward Fuselage, Brake Lines
1212 - 1512
Remove forward top fuselage.
Verify fit of brake lines. Decided to reroute two of the lines for a better fit.
Using 3/8" split loom, cover stainless lines for abrasion resistance.
Ty wrap loom in place.
Verify freedom of movement and no interference was noted.
Remove GRT fuel pressure sensor and ORB fitting.
Noted that the ORB fitting had bottomed ou on fuel pump. Area was vacuumed and inspected to ensure no foreign material was present in pump manifold.
Installed new ORB fitting with flat bottom instead of flare.
Install standard Kavlico fuel pressure sensor. Permatex #3 was used on threads.
Mounted firewall sensor manifold.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
