Bobs Ten
RV-10
Assemble Wheels, Tires, Tubes
1054 - 1406 1436 - 1518
Unpack Matco RV-10 Brake Kit.
Unpack Desser Retread Tire Kit.
Install tubes and wheels in tires, 2x.
Secure wheel halves per instructions.
Install brake disc on wheel.
Install tube and wheel in nose wheel tire.
Locate and drill axle securing bolt hole in nose wheel fork per Matco instructions.
Pressure grease nose wheel bearings.
Install Matco axle and bearings in nose wheel.
Install nose wheel assembly in fork, torque bolts.
Install nose wheel stop on nose gear leg.
Pre grease nose gear leg and fork using Super Lube Synthetic grease.
Install nose wheel fork assembly on leg.
Secure with Bellville washers, flat washer, and nut.
Need to get a fishing scale to set nose gear breakout pre load.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
