Brief Description: Finish Door Channel Edge and Prep for Primer
1406 - 1506
Finish sanded door channel edge. Found two small areas that needed more epoxy, filled these areas.
Tomorrow I will sand these two areas and apply adhesion promoter and primer to the exterior of the channel. Adhesion promoter, pimer and base color will also be applied to interior door channel area.
