Machine backside of cabin top to facilitate a flat surface for the hinge mount bolts. Using plastic washers, apply epoxy cabo mix to inside of cabin top, install temporary screw and plastic washer. Pull up on screw/washer to create a flat surface for the permanent washer and nut. Once the epoxy has cured, the temporary screw and plastic washer will be removed leaving a smooth flat bearing surface.
Apply epoxy/cabo to inside of overhead console around gas strut bracket to seal console.
