Bobs Ten
Date:  2-8-2016
Number of Hours:  2.50
Brief Description:  Fabricate Door Hinge Pocket Covers
1630 - 1900
Continue with pocket cover fabrication.
As was detailed previously, the covers were cut to fit, bonding surfaces roughed with 60 s/p, and seams were glued with CYA.
All door surfaces were roughed up for bonding.
A cover was also made for the notch cut in the door bottom for the third latch.
Epoxy was mixed and all surfaces wet out.
The seams were reinforced with 9 oz cloth.
Added cabo to remaining epoxy, applied to all bonding surfaces.
Covers were then clecoed in place and excess epoxy removed.
