Bobs Ten
Date:  2-4-2016
Number of Hours:  2.50
Manual Reference:  45-16.4
Brief Description:  Gas Strut Installation
1506 - 1736
Position the strut attach brackets against door and clamp.
Verify location of brackets.
Match drill brackets and door using #30 drill, cleco as drilled.
Remove clecos.
I decided to fill the area around the door hinges in the cabin top pockets with epoxy to prevent water and debris from collecting there.
Remove both doors from fuselage.
Cover all hinges with packing tape to provide for mold release.
Rough cabin top pockets using 80 s/p.
Install doors on fuselage.
Mix epoxy and apply a wet out coat on the area around the hinges.
Mix flox/micro/cabo into epoxy.
Apply epoxy around all hinges, remove excess epoxy.
Once epoxy is cured, I will fabricate SS covers for the hinges.
