Bobs Ten
RV-10
Install Right Door Pins, Pin Blocks
1536 - 1648
As detailed previously, usinf Vans and Planearound instructions, install SS pins in pushrods.
Enlarge pin holes in door channels to 7/16".
Trim Planearound pin blocks to proper thickness.
Match drill pin blocks to door channels, install cap screw as drilled.
Verify door fit and handle actuation.
Locate third latch block on door sill.
Match drill latch block using #12 drill, install cap screw as drilled.
Position latch cam on shaft and temporarily tighten set screw.
Verify mechanism operation.
The Planearound third latch should be a REQUIRED Modification to the RV-10...very nice.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
