Bobs Ten
Date:  10-29-2015
Number of Hours:  1.50
Manual Reference:  45-03.1>3, 45-04.1
Brief Description:  Prepare Doors for Bonding
1424 - 1518 1548 - 1624
Mark open rivet holes per plans.
Cleco door panels to fuselage using forward and aft index holes and lower window index holes.
Using procedure in plans mark doors for open rivet holes.
Drill door panels for open rivet holes using #40 drill, start in center, alternate forward and aft, cleco as drilled.
Noted one rivet was installed that should have been left open. Drilled rivet out, marked door panels and drilled hole.
