In order to fit the port wing root fairing (aft) to match mould a joggle for the port wing root fairing (fwd) I need the flap installed. To install the flap at the right position I needed to temporarily install the port aileron as well. Jards happened to be in town and could lend a hand, so we marked and trimmed, marked and trimmed and then marked and then trimmed until the flap was a good fit along the top and bottom inboard edges, which are cut at different angles to match the fuselage.
Now I can mark and measure for the holes in the fuselage where the flap pushrods pass through as well, but I won't cut those until the flap is installed on the starboard side too, then I'll put the torque tube in place to measure pushrod throw and angle changes as the flaps are raised and lowered.
