I continued the hand-sanding to see if I could remove the orbital sander scratches. This worked, mostly, but I am learning fast that not cutting and buffing within 24-48 hours of painting means a whole lot more elbow grease for an acceptable finish. I don't have the patience to hand sand the entire wing for another 10 hours, so it's time to wet sand with 800 and redo the clear coat!
