This time I decided to bond the long axis of the wall first to eliminate any slight bows, then I'll finish bonding the ends in place. I scuffed the VE resin & Aerosil down at yesterday's bonding points, then added a wide layer of carbon under the wall for extra grip, then set about laying up the fillet and thickening the flange. I was a bit too slow adding peel ply, but it was only for appearances anyway and the area can be sanded instead. When that was done I returned the tip to the wing to retain its overall shape, but only with clecos down one side.
