No-one makes composite-compatible receptacles for screw-in fuel drains, so I made my own. James helped me drill, tap and turn two receptacles that we'll later lightly bond deep into the inboard rear corners of the tip tanks and also rivet with a couple of dash-3 NAS1047 rivets to ensure it doesn't rotate or depart the scene if I have need to remove a fuel drain for some reason.
