Stuarts Web Site
Date:  5-15-2016
Number of Hours:  1.50
Brief Description:  02 - Wing tips
Wing tips
I drilled the primer out of the rivet holes around both filler flanges, then sanded the hole smooth and checked the fit of the flange itself. Once that was done I taped off the visible part the upper flange and trimmed away the excess tape with a scalpel blade, before applying ProSeal to the flange, the lip of the hole and countersunk rivet holes. Lastly, I soft-riveted the flange in place, dop'd on a liberal coat of ProSeal to the underside of the flange to seal off the edges and rivet heads and scraped away the excess from the tape on the upper side. I'll leave the tape in place until finish painting is almost complete.
