I drilled out the AD4 rivets holding on the inboard aileron attach bracket, flat squeezed the rivet holes in the doubler and spar, then applied some gentle rubber mallet to the same area to straighten the slight bow. We could see the area straightening up and when I re-cleco'd the bracket on, everything was straight ... phew.
