Brief Description: Wing and control surface priming
As I did with the rudder and elevators, I scuffed all the rivet lines with Scotchbrite and dop-sticked 2K primer onto each rivet head to seal them. This will prevent uneven finish around the rivets when I spray fine coats of primer across the whole surface. I'll sand the drops flush beforehand of course.
While I was at it, I did both sides of the opposite aileron and flap and one side of the horizontal stab.
