James and Tony and I began riveting the lower wing skin. Thank goodness the first three root ribs are removeable, because you need to be a contortionist octopus to reach in there to buck the rivets wherever the rib spacing is closer than about 10 inches. We hand-squeezed the rivets around the inspection ports and dragged the fuel line through one rib at a time once the nearby rivets were bucked.
