I laid up two more doublers on the outside of the wheel pant, which I will cut the doors from later. I then trimmed the previously molded doublers, cleco'd them in place and slowly trimmed one of the tubes until it fitted perfectly on the inside. Then I simply sanded the surfaces and epoxy & Aerosil'd the tube to the doubler in situ. Later I'll remove the bonded parts from the pant for trimming and to fit the door hinge.
