Stuarts Web Site
Date:  5-3-2012
Number of Hours:  1.00
Brief Description:  Ground terminal
Ground terminal
Tonight I started machining an aluminium bronze ground stud to pass through the firewall and the forrest of ground tabs. I made the dimensions shorter so a 2mm silicone washer will fit against the firewall for vibration damping, strain relief and to minimise corrosion.
