Tongiht I fitted the main electrical conduit to the centre tunnel and added one of several P-clamps that will be fitted as I work out exactly where to place the wiring run. I need space through the main spar for the pitot/static lines, smoke oil and aux fuel line as well. I temporarily ran a second conduit to check for clearances. I plan to cut the conduit close to the centre to break out wiring to the stick grip circuit board, TCW Safety Trim, TCW Intelligent Flap Controller, autopilot servos and the aileron trim motor.
