Tonight I added most of the bus bars to the underside of the ciruit breaker panel. When I've finished planning how to integrate the schottky diode between the transponder and TCW Independent Backup Battery System, then I'll solder the folded bus tabs together, connect lengthwise bus bar on each side (controlled separately through the master power and avionics master switches) and then join the remaining connections with jumper wires to the appropriate bus.
