I wired up three double pole relays that interrupt the signal wires from the rear stick-grip. The trim function is switched separately, but all the other functions (fuel/smoke pump, comm, flap, start and control wheel steering) are controlled by relays so that I only need one extra switch. They will also light up a 'rear stick-grip armed' light on the panel.
