Today I began fabricating the circuit breaker panel. Unfortunately, my best laid plans need modifying ... the label gets twisted as the lock washers clamp down and the spacing is a too close between the screw heads (to prevent arcing), so I'll remake the labels, open out the holes so they're larger than the washers and space the breakers further apart.
It will look neat when finished ... and I plan to add a spring-loaded map storage pocket and folding knee board.
