James and I remade the stainless strip around the leading edge of the canopy slider. This time we started with a wider 0.020" stainless strip, match drilled the holes, dimpled, trimmed the front edge to match the plexi and then the aft edge to match the front. This was necessary to account for the compound curve in the plexi, which causes the trailing edge of a parallel cut strip to sit slightly proud of the surface.
When this is riveted in place, then we can rivet the glare shields, final trim and polish the aft edge of the windscreen and prepare to lay up the composite winshield retainer ... yay, I've been looking forward to that part :-)
