Brief Description: 02 - Right slider side retainer strip
I wasn't happy with the narrow white HDPE strips to retain the upper screws along the slider plexi, so I had wider black HDPE strips cut. James and I radiused the edges with the router, then match drilled to the ally strips with a #40 drill, tapped to # 6, trimmed the ends to shape, polished with 400 grit wet paper and fitted them to the canopy.
