I put the slider plexi over the canopy frame and set the position per the plans, just aft of the instrument panel bulkhead. I then proceeded to trim the plexi four times, just to be sure I didn't overcut the ends or sides. It appears the top is too high for the speedslope windshield, so I may have to resort to lowering the front bow some more. This will require filling the truck locating holes with weld, but it's doable. I just hope it doesn't upset the orientation of the rest of the slider frame too much, since it took so long to get right in the first place !
