String-lined and marked for the rudder cable runs through the bulkheads. I will be running the connection between the rear and fwd rudder pedals through the bulkheads as well, so the plan is to make new cables that run the full length (around a pulley at the front bulkhead) and to use a ball ferrule part way back to connect the rear pedals.
