Fitting the Velo racing seat to the Rocket is a tricky. There are two parallel rails on the underside of the seat, but the center section (for butt cheeks) is lower than the rails, so the seat doesn't sit flat when measuring.
There is also a fine line between getting the seat low enought for pilots head to clear the canopy, having the crossover bar is aligned with the recess in the seat and positioning so the lap belt attach points align with the through holes.
