I moved the pitch servo 5/8" further aft then turned and threaded a new connecting rod in the lathe. I then trimmed, alodined, primed and painted the belcrank brackets and trial reinstalled with the servo overcenter limiter bracket in place. However, the servo limiter sits between the servo and belcrank brackets, so it will need to have some material trimmed off the bottom once I am sure on the right orientation to suit the movement of the belcrank itself.
