Stuarts Web Site
Date:  7-9-2009
Brief Description:  Autopilot pitch servo
I fitted the autopilot servo to the new belcrank brackets per the dimensions in the Dynon documentation, but discovered there isn't enough room between the servo motor wires and battery (even with the battery at the full forward position in its tray). I will have to drill new holes and push the servo further aft. I will need to extend the servo connecting rod by the same amount, but can't see any reason why this would cause a problem. It will also put more space between the connecting rod and the joggle on the belcrank, which comes very close at full backstick.
