Brief Description: 01 - Passenger seat belt attach points
While contemplating how to fix a clearance problem between the flap linear actuator and the port side passenger arm rest, I decided to remove, shape, drill, install nutplates and reinstall the passenger seat belt attach points. This all worked out pretty well and while I was at it, I measured the exit points for the seat belts to pass through the arm rest panel.
