Stuarts Web Site
Date:  6-17-2018
Number of Hours:  1.50
Brief Description:  02 - Floor panel doors
Floor panel doors
I rip-sawed some square balsa wood down the middle to make triangular section, cut to size and glued together to form ribs in the floor panel doors. These will be sandwiched into the door panels around the Hartwell latches and should cause enough stiffness in the carbon fibre to stop excessive flex in doors when stood on.
