I want to connect a 12V receptacle directly to the main battery for charging from outside and also to run low power devices such as an LED light if required, so I made a mold for a carbon fibre socket with a large flange. The male half is tapered for easy removal, so I built up enough layers of carbon to be sure the space between the two halves of the mold would fill under clamping pressure. When that sets, I'll turn it in the lathe to make a tight fit with the cigarette lighter adapter and fabricate a spring loaded cover plate and doubler for the fuselage.
