First I countersunk all the attach holes for the SkyBolt floating adjustable camloc receptacles, then traced and opened out each centre circle, deburred and smoothed the holes with fine sandpaper. Later I'll do the same for the lower cowl, but clecos won't work now, so I need to drill and sleeve the actual top and bottom cowls or I won't have a way to secure them in place.
When that's all done, it might be time to remove the engine and mount, shape the flange around the receptacles and finish prime before riveting the receptacles for the last time.
