James and I cut three pieces of 2" ally tube and TIG welded them together to make a branch for the pilot cabin heat duct. The sides of the branch will run to two punkah louvres, one on each side of the tunnel beside the pilot's feet. The tube walls are 2mm, so with plenty of material to work with we die ground the excess weld metal away to cut down on the weight. Next we'll make a branch at the front end with 1 1/4" stem and valve for the winshield defrost SCAT tube.
