Brief Description: 01 - Map holder springs and door
I wanted slightly more tension on the springs, so I attempted to close them a little more. I knew this would be tempting fate, given the temper of the spring steel ... two broke. At $3.95 for six I can hardly complain, so I'll buy another six and experiment until I get the tension right.
I finished priming the parts, then riveted the hinge and the two pressure plates to the door and made a tab to lock the hinge pin in place.
