I made the crescent twice because I wasn't watching for alignment with the front of the boot cowl area as I drilled the fixing holes on the first. I cleco'd a piece of thin polycarbonate sheet to the glareshield to mark the positions of the bootcowl crescent holes, then slid the crescent underneath the poly sheet. This way I could easily see the spot to drill, working from the centre outwards while holding the crescent down in alignment with the firewall using a ruler laid on its edge. This worked out quite well.
I also want the GPS antenna cable forward of the instrument panel. The antenna is passive and shouldn't ever need to be removed, so I'll use nutplates and my tiny ratchet handle and stubby #2 phillips driver bit to secure the screws from inside the windscreen ... wish me luck :-)
