Stuarts Web Site
Date:  6-17-2012
Number of Hours:  0.50
Brief Description:  Smoke oil line
Smoke oil line
I spent quite a while trying to bend up the smoke oil line between the position of the valve at the front and the filter at the back. It's a complex path with little clearance from the centre torque tube. Ultimately, I decided to reposition the filter slightly to so the complex parts come in two pieces and so the filter is down low and gravity fed rather than above the fluid level most of the time.
