I fabricated lines to connect the electric fuel and smoke pumps to the firewall passthroughs. The Speedflow lines and fittings are easy to install and look awesome. The dash-6 and dash-8 lines are carbon-lined to prevent static build-up that can arc through the Teflon that might cause pin-hole leaks.
