Brief Description: 03 - Brake line bulkhead fittings
I measured and drilled for the brake line bulkhead fittings. I don't have enough straight dash-3 hose ends to complete this job yet, but it will be done soon enough. I'll add a P-clamp under a fuselage bolt down low on each side as a guide to ouput the line behind each gear leg.
