I drilled all the nutplates off the instrument combing to add the attach flange for the glare shield. This should have been installed before, but it was an easy fix.
I also machined two spacers to fit between the instrument panel coming and the # 5 bulkhead, so that mounting the purge valve and brake cables doesn't squeeze this area out of alignment.
