Used Tom Martin's suggested way to closeout the VS (same process as HS) with the exception that I will use Cherry rivets to hold the middle rib to the aft spar (so that I could rivet both root ribs to the forward spar first). The small Tungsten bucking bar sure is handy for solo riveting!
