Trimmed the lower rudder tip rib to 5/8" and riveted to the upper tip rib. The joggled flange is very loose in the rudder spar which is at least 0.32" wider than both tip ribs. The counterweight skin rivets to the spar on the lower side and the ribs on the upper, so it concerns me that the skin will look bulged at this point. The epoxy rudder fairing doesn't fit particularly well either, so it looks like there will be a lot of work to do here later.
