Marked and drilled the remaining holes for the stiffeners, deburred and dimpled for riveting once the skin is ready. Must remember to rivet the mid FWD rib in place before the in inboard upper stiffeners - not even my wife's arm would fit between the stiffeners once the skin is on.
Yes, they're offset far enough not to touch each other when the skins are closed !
