Brief Description: Drilled tailwheel spring taper pin
Fitted tailwheel taper pin
Drilled weldment through to tailwheel spring with #40 drill; drilled tailwheel spring through, replaced spring and drilled weldment lower side then outer skin. Opened outer skin to 19mm and deburred. Drilled out spring and weldment to 1/4", then taper reamed the spring slightly undersize before replacing the spring in the weldment and reaming to match fit holes. Instered taper pin, taper pin washer and nut.
