Brief Description: Elevator trim servo and cover plate
I sanded the trim tab and trim motor cover plate with 500 grit wet and dry, rinsed, cleaned with wax and grease remover and sprayed with white base and clear coat. Once that dries I can install the components and drill the port elevator horn for final balancing.
