Tonight I mounted and aligned the VOR antenna on the newly machined block, taped off the area, kneaded moulding wax into shape and then layed up a male fibreglass mould for the fairings. Later I'll probably turn an Acetal barrel to slide over the whip and glass it in place, which will act as a drill guide to align the hole in the moulded part later on. When that is done I can smooth the mould and vacuum bag mutiple fairings for surface finishing. The part will be held to the VS with 3M 300LSE double sided tape ... just like a stick ... super sticky :-)
