This afternoon James and I designed a lightweight HDPE spacer to fit between the VOR antenna base and the upper rib in the VS. The holes fit around the new nutserts and most of the unnecessary material is removed to save weight. The rear hole fits close to the COAX conduit, so the spacer needed to be a different shape at the rear end. I covered the bottom with HDPE leading edge tape and trimmed to ensure vibration can't cause the part to cut into the VS rib.
